billyb
Ok I just installed one of Mikes basic speedometer on my build and am wiring the dash lights without a problem. Back light, neutral switch, high beam all check out fine. Blinker signal not so much the lead has a ground and positive so thought I could just jump the positive to left and right signal nope. If I tie into one side the dash light blinks fine when switched on but wired to both sides all four signals flash and in the off position the dash light keeps flashing. Oh and I have LED signals with a LED flasher relay which works fine but so could that be the problem what am I missing in trying to get the dash light to blink with each side and shut off when lights are off.
wiring is not one of my stronger aptitudes so any help would be greatly appreciated.
