It's an interesting idea, but I see a few drawbacks if used in the home:
It's 12V, so you can't plug it in to your house electricity.
It's diesel. One more fluid to have to keep around, unless you already have something else that runs on diesel.
How noisy is it?
The traditional garage heater is the forced air propane type. Harbor Freight has one for $99 that is rated at 30-60K BTU. Definitely noisy.
Yes the 12V is a pita, but I have a 110v power supply I can plug into the wall to power the device. Yes it will be another fuel to keep on hand. Noise levels don’t appear to be very high. I watched one YouTube video where the guy was taking actual measurements of the noise. I’ll try to find it an post some numbers. Of all the vids I watched, noise didn’t appear to be a drawback.
I don’t think it has a thermostat and this is a drawback. There are different, selectable, output levels, but to manage temps you need to turn it on and off yourself. The output levels appear to be different fan speeds. Faster speeds = more heat (and sound too). For me, I’m thinking about using it to “boost” heat in the garage, then letting the electric heater maintain temperature. My electric heater can bring temps up to 10-20C, but works very long and hard to get it there. Supplementary heat needs to be fossil fuel driven because I’m out of power in the garage (only have 30A @ 220V - my current heater eats 20A of this).
The garage heater you mentioned is like a construction or salamander heater. I’ve owned a couple, one diesel and one propane fired. They put out a tremendous amount of heat but are quite noisy and the unwanted byproducts of combustion (water and carbon monoxide) are introduced to the space you are heating. When I used to run mine in the garage, anything metal and cold would be covered with a heavy layer of condensation within an hour of operation. That was a deal buster for me. This diesel heater exhausts combustion byproducts outdoors so all the moisture and CO it produces is kept from the inside of the space you are heating.
I believe it is a Chinese knockoff of a Webasto heater. I’ve known about and have seen many Webasto’s running in the past. They are great heaters but carry a price tag into the $2,000+ range. That’s where I lost interest.
I may take the plunge and be the guinea pig for the group to test it. I’ll wait a few days to see if others have any experience with this.
edit: this guy has a cool trailer conversion. The vid is about the noise from the fuel pump. I suppose it would be annoying if you’re trying to sleep in that space.
@Jim , is this something you could use in your van project?
