ippytattoo
Just another grumpy old hack.
I was doing a little work on my bike, Deep South XS, and got my headlight wired up tonight. I was running my bike to check and make sure that both the low and high beams were working properly and found something very odd. Both functioned as expected but when I raised the rpms from idle the headlight and gauge back lights dimmed, I would have figured they would have gotten brighter not dimmer. I am sure it has to do with the non-standard battery I am currently testing (a 12v battery from a computer battery back-up) to see if it will work as it is about half the size of a standard battery. I have yet to test the voltage at the battery with higher rpms but at idle (600-700 rpm) I am getting 13.5v. I am running a PMA swap with all new wiring and and new headlight socket. Has anyone out there run into such a situation? If you have what did you find to be the culprit?
