Me, personally, I think I would make the effort to try and recover the broken off piece.
Here is the end of your dipstick, right here sticking into the starter gear case.
If you’re lucky it simply will be laying in the bottom of that case, it’s a simple matter to pull that cover and look, you might have to replace the gasket if it tears on you.
If it’s not in there, then hopefully it’s down by the drain plugs, maybe even stuck to one of the magnets. I’d pull the sump plate and take a look around. All it will cost to do a little looking is some oil and gaskets. You could save yourself some trouble. My 2 cents.
