Just one last thing I'm hoping someone can help me with as I put things back together. I'm on the left side now, got the starter gear cover back on and am trying to put the left side engine cover back on.
I pulled the clutch cable through and inserted it into the holder:
And then put the cover back on, trying first to do a "dry run" w/out gasket to make sure things work, but when I pull the clutch lever, it feels very soft, and it doesn't spring back. There's too much cable play, as if it were too long, but I didn't do anything special, just removed the cable from the holder / sping when I took the cover off. Am I missing something? At the clutch lever area, the cable is fully inserted as it was when I began.
Also: I'm assuming that the rod that sticks out, need to go into the hole by the spring on the back of the cover. That rod seems to pull out easy, should it be pushed all the way in?
Thanks...I'm getting close to getting back...to where I started : )
