Early Speedo help
willis
xsive compulsive disorder
XS650.com Supporter
Northern Indiana
I am preparing to do an overhaul on my 72 gauges with the help Bob (Mailman) and Steve’s (2many) incredible tutorials. But the biggest hurdle I can’t get past is the first step... lol. I cannot get the screw out of the tripmeter knob. I have several sets and they are all the same. That little screw head is worn out and I can’t unscrew it. Is this where I just have to bite the bullet and drill the head off and just grab that little booger with vice grips to get it out?
I was just reviewing my old posts. If that screw head is stripped out, you may not have many options , but to drill the head off . There’s just no room to reach inside that knob.
Yeah, that's one tiny screw.
Normal right-hand threads.
Flat base under the head, and threads deeply into the aluminum shaft extension.
Good luck drilling the head off...
Well my immediate success in drilling the head off this morning was followed with immediate failure.
A916A632-B374-44BC-92E2-12926280056D.jpeg D2151102-FDD3-41C4-B878-29396FFE946A.jpeg
The screw appears to be brass and drilled quite easily. But once I gripped the remaining shaft with vice grips it immediately twisted off flush with the shoulder. This reset knob will get shelved in my parts stash once I get the reset assembly removed. Fortunately I have been collecting early gauges for a bit now and have a couple others to scavenge parts from. Another gauge proved fruitful when its screw cooperated with a bit more effort.
ok, strike two... I just tried the soldering iron trick to release the thread sealer but got nothing. The knob will rotate around backwards but is not dis-engaging from the threads. Is it critical to remove the E-clip inside the gauge before attempting to unscrew the knob? I really want to take the chrome bezel off before trying to uncrimp the face bezel.
upon further review of MM's thread, I really need to get in there farther on the shaft with the heat to melt the thread lock. Looks like i'll be un-crimping the face bezel first to get that booger off.
Yeah, they are a pain to get apart. It’ll test your patience!
