Im working on a 81 xs650, all stock charging system/ignition. I have a relocated fuse box inside a fake oil tank under the seat. When going to adjust the Carb Sync screw in the middle, I am noticing a spark/arcing that will jump from the screw driver to the frame when I am on the carb sync screw. I can also make it jump from the engine to the frame in the same fashion. If I touch the screw driver to the Engine Case vent tubes to the frame it does the same thing.
I have checked that my coils are not to close to the frame, and that my spark plug wires/boots are not cracked. I replaced the spark plug boot end, and the coil end when doing a refresh on the bike a week or so before. I am not getting any arcing from the spark pug wires to the case/engine at all either. I have checked the condenser wires that are under the tank/frame and covered those in some heat shrink to make sure nothing is arcing or shorting out. I've tried to get the engine cases around the top to arc to the down tube on the frame, and nothing, and the same with the fork tubes to the engine case/etc.
The spark is an orange spark, and almost is similar to something shorting out. I believe this is only happening when the bike is running, so I would think its a charging issue that is causing the arc.
Anyone have any ideas what it may be?
I'm in the middle of the build, so I do not know if this has been an issue before. The bike does run, but I am waiting on other parts to finish up the carbs before I can do a full tune up.
