HrdnSwede
Weird title huh?
Simple question though: Which way does the engine in a XS want to twist when you gas it? Backwards/up for a wheelie or forwards/down to keep on the ground?
Reason I ask is because I haven't gotten my project running but like to know which way to eventually 'preload' the engine to take out slack from the engine mounts. Doing a bunch of custom fab work including exhaust and the difference in movement up/down right now with just the bolts sitting un torqued/tight makes a difference where things will fit and clearances that will mater later.
