Ok guys more progress tonight. I decided to get the front end off the frame to prep it for the hardtail. I've never taken a front end off before. If you've never taken a front end off and you're reading this...it's very easy. Here's how you do it.
Sorry for forgetting to snap the before picture, but if your front end is assembled, just look at that and there's your before lol. The front end is held on by the top triple tree and a set of notch nuts below. Here is what the hardware looks like from the top tree. Three bolts and one nut in the center.
When removed they look like this
Those four rubber units hanging out in the back are the handlebar bushings. Two per handlebar riser, one in the bottom and one in the top of the open gaps you see in the first pic
After removing the hardware in the picture above, you can work the top tree off the fork sliders. I did this by pulling gently on the left then right sides in small increments until it freed up. Mine likely hadn't moved in a while, yours may come off easier.
Next you'll see this below that top tree.
I used a punch and hammer to knock this nut counter clockwise.
It loosed to finger tight after a few rotations. Be careful not to mar the nut too badly. It should loosen and begin to move up and off the threads to the smooth part of the stem. Lift both nuts and the spacer off.
You will be left with this
This unit is friction fit into the neck via the tapered reeses peanut butter cup bearing. It probably has a more official name. It's greased quite liberally, so have a rag nearby.
You can now lift this bearing out
At this time I decided to lift off the headlight brackets as I'll be running and aftermarket headlight. They come off very easily once the top tree is off. If anyone is interested in these, $15 plus shipping and they're all yours.
If your bike was resting on the wheel, you'll see the front end shift a bit as you remove the bearing. It was friction fit, so removing it allows the stem to move within the neck. See photo below with cranberry sauce
From here you can lift the frame up and off of the front end. Easy as pie. You'll be left with the front end and frame in two pieces.
Already posted this pic, but posting again to remind you that if you want to remember how this all went together before you removed it...either re read this post or reassemble the top tree on the front end to avoid losing pieces! It will look like this
And you're done!
