Hey guys, popping back in as it's been quite a long time since my last post. In the meantime, I've been waiting on those Cruizinimage pistons from Japan, cylinders are over at the machine shop, crank is at my local shop getting inspected as well so the progress can't move much until the parts arrive and inspection is complete.
Engine internals aside, I've got a question on which I've done some extensive research but can't find a clear answer. I mentioned earlier in this thread about a desire to use the joe wiseguy 2-1 intake, as I've never owned a bike with two carbs and don't plan on starting now lol. I've poured over the TeeCat thread, which I'll link below for anyone who is reading this and may be interested in the information.
http://www.xs650.com/forum/showthread.php?t=3647
The only issue with the information provided here is that it pertains to the "tracker" version of the 2-1 intakes. A similar style is also sold by CounterBalanceCycles which many have used with great results.
I'd much prefer to use the "bobber" version as it sets the carb a little further away from the hot engine fins and frame rails. After some horrible experiences trying to tune my road star carb while avoiding first degree burns (because tuning requires that ride it, mess with it, repeat type process) I decided that this bike is going to be built with a focus on ease of maintenance, in the hopes of changing my neglectful ways.
My concern is with runner length, and the angles of the bends on the runners themselves. Here's the carb I'm looking at
http://www.joewiseguy.com/bobber_2_into_1.html
If anyone has had experience with it, and can lend any insight into jetting I'd be curious to know how it differs (if at all) from the TeeCat suggestions I found below. Research has shown that longer runners often require richer jetting to account for the increased distance between carb and cylinder, so I'm hoping to avoid purchasing more brass than I need by starting off closer to where I need to end up.
25 PJ
200 MJ
159-P8 Needle Jet
6F9 Needle Clip in position 4
Air Jet Removed
A/F Screw 1.5 turns out
EDIT: I live right on the water so my elevation is 0. I live in the Northeast, USA so temperature also fluctuates greatly in my area, if that matters at all.
Thanks guys!
