A little more progress tonight, didn't have any gasket sealant on hand, but wanted to see how difficult it would be to get the system aligned and reassembled. Ended up putting the head on, and sliding the cam under the cam chain as well. Sure was a pain getting it in there and back out lol. Need to get some sealant today so I can seat this tonight. Also, there seems to be two different markings on the cam itself. One is a small circle near the teeth, and the other is a rectangular cut closer to the base. These two markings don't line up with each other and I'm wondering which should be at 12 o clock during assembly. In Nightflyer's video it's the rectangular one near the base that he uses as the reference.
Also, he mentions that the engine should be at TDC when aligning this marker. My PMA is not yet installed, should I be doing that first? Maybe I ought to torque down the three bolts that hold the lower head onto the cylinders so that I can rotate the engine to TDC? What's the best way to turn the engine at this stage in the rebuild?
Also, I was pretty worried initially when looking at the remaining orings as I had no idea where they would all go. Upon closer inspection and sorting, it looks like it's really only six locations which will need these installed. One of which I heard nightflyer mention in his assembly video as being under some of the bolts in the heads. Not sure exactly which, but maybe someone here can lend a hand.
Lastly, I purchased this 110v 90amp Flux Core welder. However, it seems that if you read enough about it online anything short of a $4,000 TIG machine is just regarded as a POS. I'm looking to weld simple things like the 3/16" mild steel brackets for the fender, sissy bar, gas tank bungs, brake pivot and whatnot. Is a machine like this going to be capable of doing that? It's not heart surgery, but honestly the reviews have me a bit worried. I haven't opened it yet so I can still return and get something else.
Thanks guys
