I think your head bearings are toast. if you jack up the front of the bike so the front wheel is off the ground, grab both legs and try to push them back and forth. do they clunk? feel loose?
now turn the forks lock to lock. does it feel 'gritty'? or tight?
it should feel smooth, and easy to turn. if its too tight, it will feel like its 'racheting"
That vibration can be tuned out. Getting both cylinders to pull the same works wonders.
If a points bike getting the point to fire as close to exactly the same time helps, A more precise carb sync helps. Eliminating as much of the variables between left and right smooths thing out.
