Got it put together used 10 weight added a bit of tungsten disulphide, did a test ride on the "county's worst road, then repeated the run on resto that has mikes emulators.
random thoughts. That road is BRUTAL! Thought the "mintoned to death" madness forks were a bit less harsh. both did OK, considering.
I think the stiffer springs and resulting slightly higher stance helped stability, could induce a weave at 80 MPH plus but it didn't start in on it's own like before. On normal rotten WI roads ride is fine or better. I prefer it to the stock marshmallow fork feel. the "light weight" dual disk set up is a big improvement over a single disk.
Think it will stay like this for a bit. May install the mikes emulators "later on" But honestly next up is more likely to be a FZR600 fork I happen to have.
Related; I'm not that impressed with the fork brace not sure it adds much stiffness.
