browntown
hello! It appears i am in a dysfunction relationship with a 39 year old yamaha. i have a TX650A.... i think. (It appears it was laid down at some point and some parts must have been damaged and replaced...ie. gas tank is from a special maybe???) anyway, to the matter at hand. my plugs are fouling. here they are:
now i have been searching and reading a ton to figure out what i am doing wrong. so here is my theory. i am running rich. i need to change settings in my carbs. especially the right one. so i ordered a rebuild kit from mikes. i got the one for the tx650A. i should have done more research.... because these two pieces were not like the ones in my current carbs. the gasket wasnt quite the same shape, and the metering needle was a few millimeters shorter than what i have
so i figured i dont have the carbs i think i have. so i have been scouring the carb guide and the german translation bs38 carb identifier (i am sooo confused) but here they are. i cant find any markings on them, i have looked, but i figure i must be missing something.
it seems to me from my reading of the carb guide that i need to have the correct settings of the carbs i have, and not necessarily the model year of the bike.
was my carb rebuild kit wrong? do i have the original carbs? are these for the tx65A?
when i have new plugs the bike runs like a dream for about 10 miles and then it starts getting funny. it starts to idle high and then the right side starts sputtering and soft backfires (not a crazy loud backfire, but a backfire nonetheless). it then dies and i have to push it home. sometimes with the chock on i can get it to sorta run and limp home. (i stay close cuz i have been having this trouble, so i am usually only a block or two from home)
is this a carb setting issue?
is my ignition system not supplying enough spark after it warms up?
is the right side fouling from oil getting past the rings?
this is the stuff keeping me up at night for the last year
please help. i need to know where to start i have eliminated other problems that were getting in the way. replaced leaking vacuum petcocks with manual. took off loose airboxes that werent sealing (between or on carbs) with pod filters.
