tbone1980
I can not get the front sprocket off for the life of me! I tried bunching up some old chain links which worked to stop the gear from turning but with a three foot breaker bar attached to a 36mm socket I couldn't get it to come loose. I have used penetrating stuff on and that didn't help either. Just to make sure that I'm not missing something here it does turn to the left to loosen right!?!?!? One note to others don't bunch the chain against the lip the is just at the top of the gear where the engine casing meets the aluminum cover because I found out the you can bend it... Thanks for any help you may have for me.
