I don't trust the glass fuses. The element can break down in the cap and you can't see if it is blown. The element can come unsoldered from the cap. Again you can't see that.
I have had way to much aggravation late at night, on some lonely back road, trying to tell if the fuse is blown.
The blade type have no caps and on many you can see the entire element. The element and the blades are made from one piece. Can't come unsoldered. Much more reliable fuse.
On the fuse blowing, depends on just what is causing the trouble. A short may need the heat to expand the bare parts to get them to touch.
I see you have the Pamco. What coil are you using. It may have an internal short that only shorts after the coil warms up.
Generally if you remove parts the load decreases, so a lower amp fuse can work. Like on the turn signals, with the stock bulbs the curent draw with two 27 watt bulbs is somewhere around three amps, so a 5 amp fuse would work on them. Convert them to LED and the current draw is somewhere around .5 amps so a 1 amp fuse would work.
When the fuse blows start checking the system as soon as possible, before it cools off. Or perhaps with the meter hooked up, warm the parts with a hair dryer.
