Well, after a one month hiatus, I did some work on the beetle again. Tried to figure out the seized or frozen LF suspension. Thought if lucky it would be a seized shock but no such luck. It’s highly unlikely it’s the spring leaves in the front beam so it’s probably frozen link pins in the front knuckle. That can wait.
Decided to install the left swing axle boot. This required raising the trailing arm to get clearance to get the boot in. I removed the shock, raised the arm with a jack and installed a 14” piece of 5/16“ chain to keep the suspension “loaded” so I could remove the jack. It looked a bit sketchy, but seemed safe so I went ahead with the install. It’s a split boot and one needs to be careful to not overtighten the small screws.
For this corner of the car, all I need to install brake lines and drums and it’s done, until I need to bleed the system.
Big day today - I got my container of red rubber grease at last!
After dinner I put the first hard and flex line in.
