1. Dismiss Notice
    Dismiss Notice
Governor springs , changes over the years?
Discussion in 'The Garage' started by XS650D, Aug 13, 2019.
  1. XS650D
    XS650D XS650 Junkie
    Ordering new Advance springs (NOS new old stock) looks like there was a change
    between 75/76 years based on part info looking at. Can anyone confirm if this is indeed
    correct.Not sure what the diff would be. I think I saw that certain years had a different rpm
    range ,maybe 3000 vs 3200 rpms max advance .Thx
  2. XS650D
    XS650D XS650 Junkie
    OK Perfect,Thx Gary, got a set on order, will be interesting to see what a properly tensioned stock advance spring set
    works like compared to my bastardized Mikes xs units. Really wanted an electronic advance but no go here in Canada
    purchasing separate . Actually I think Mikes in US is same now. Well I think the original advance will be great with new springs
    and no drag from points with the Electronic ignition I have installed.
    gggGary likes this.
  3. Rasputin
    Rasputin XS650 Addict
    I suppose when all said and done the changing of ARU springs would be an attempt to alter and refine the advance curve, making the engine sweeter in different areas.
    Those of us that remember manual AD/RET will know how crude it was. Velocette for instance, start half retarded then onto fully advance for riding, if it struggles going up hill retard it a tad.
  4. gggGary
    I've never bought mike's springs but I've shortened the stockers a time or three. I try just one spring first, check action with a light, do the other if it needs it.
  5. FatChance
    FatChance XS650 Enthusiast
    44
    55
    18
    Wi
    Anyone have a source for the small washers and clips for the governor assembly?
    Charley
  6. XS650D
    XS650D XS650 Junkie
    Ive lost mine long ago but have seen no issues as of yet. I still think there a good idea especially the spring washer
    keeps things aligned better and may contribute to less wear on the weights ect.Im sure theres a spec on size and can be ordered thru a hardware company.
    but I believe many just forget about it once there lost.The New advance unit Mikes sells I dont think come with the washers either
    so maybe they feel its not necessary.
    FatChance likes this.
  7. FatChance
    44
    55
    18
    Wi
    Thanks. I’ll skip the washers and get the clips from Mikesxs. It was very dry and a little rusty in there so I’ll add little lube when I reassemble.
  8. DogBunny
    DogBunny Motorcychologist Top Contributor
    I bought a pack of these a few years ago. They are a direct replacement, and are considerably better than the originals which are soft and tend to spread after they have been removed once or twice. I'll mail 4 (enough for two advance mechanisms) to anyone who PayPals $4 to me as a friend to:
    william@handspiral.com
    Be sure to PM me your address.
  9. FatChance
    44
    55
    18
    Wi
    Thanks, will PM you tonight.
Share This Page
