Define "broken." Bolt threads stripped? Hole threads stripped? Or bolt literally broke in two?
And that's why we have the aforementioned formula. We don't care about the angle... it's irrelevant to the calculation. What's important is the distance.We would need to know how to calculate it at any angle, for a proof.
Get a new bolt. Your local hardware store should have grade 8.8. While you're there, buy a tap to chase the threads out on the cylinder.It’s broken near the end of the threads on the bolt.
How many threads do you think are catching?It’s broken near the end of the threads on the bolt. Those threads are just stuck in the casing. But there’s enough thread in the bolt itself that it catches and tightens a bit probably not 7 foot pounds though. This isn’t the bolt but if it was this is about where the thread broke off
The change in distance a crows foot makes is so insignificant that it would be hard to even measure it.Then you're saying any crowsfoot is off at 90, because the red line is longer. Would you suggest a correction factor of R/G ?
Not sure I’m gonna just assume 1-3 it’s been about 2 weeks since I seen it last. The retorque definantly helped but I still have some leakage and I think some of it has to do with that bolt unfortunantly. When next season rolls around maybe I’ll take it out change gaskets and remove that stuck bolt get a new one. Here a pic of the leak I have left if it helps. Thanks dudes!How many threads do you think are catching?
...This is the kind of thing 2M likes to work on...
...E becomes 0 the minute it goes on at 90 degrees...
...Applied force times distance equals resultant force...
...This is what I've always heard before...View attachment 120799
The red line is longer than the green. That greater distance means a higher resultant force.
Yes.Is this something I can get at Hardware store?
Both correct, but missing an important vector.
What's unclear is the vector.
