How about remove the crankcase breather cover assembly. I realize that would necessitate buying/ making a new gasket but that way you could get a long wobble extension tight to the top frame tube and it wouldn't be on such an angle.
I'm gonna throw a word of caution out here that I'm sure everyone is aware of... but it bears repeating....you will see the importance of lubricating the threads and under-head area of fasteners to ensuring true torque readings.
and that darned near impossible to get at tiny little bolt above the chain tensioner! Start by loosening, good chance it is loose anyways. Then GENTLY snug it up. At ANY sign it's starting to pull tiny aluminum threads out of the head, STOP! Quick recap; it should turn freely then you should feel the bolt head make contact with the cam cover, now it will take up just the slightest bit of clearance between cam cover, gasket, and head. Stop now and revel in the wisdom in your fine mechanical feel.It shows max torque for lubed 6mm bolts into aluminum to be 4 ft-lbs. Think sump and sidecovers.
38 Nm=28 ft-lbs. 19 Nm=14 ft-lbs. Do those numbers look familiar at all, gents?
I use a similar one called Convert. I used to require my students download and become familiar with it.I have a neat little free metric conversion program that really comes in handy for stuff like this.
Yeah... what that NASA paper alluded to but didn't go into detail on is re-used fasteners. The more a fastener is used, the more "polished" the threads become. This polishing reduces friction, thus increasing the amount of tension applied for a given torque. Add to that each "tension cycle" gets us that much closer to metal fatigue... and it's completely understandable why older hardware tends to strip easier...But on these old bikes and alloy cases, I'm starting to back that off a little now, into the low 70's (about 6 ft/lbs).
Well Steve... after reading that thread, it's becoming clearer to me why we're all over the place on this (I suggest you guys give it a read). You put up a shot of your "old Yamaha manual" that clearly stated you are to lube the head fasteners. My 78-80 manual says no such thing.Pete, Jim, another one that could use ya'll's critique.
http://www.xs650.com/threads/what-to-use-on-the-bolts-for-a-top-end-job.27533/
Any of this helping you reach a decision Paul?Should I be reducing the torque settings to 20ftlb lubricated to be equivalent to the specification 27ftlb dry?
