dimka pdx
Hi all,
I've been wrenching on this bike (pics below - 79 XS 650) for a while now, as time permits. I am just in the final stages of getting some fiberglass work done, and make sure I get all the wiring figured out before breaking her down for some paint and powdercoating.
Here is my question for all you electrical gurus out there --> I am trying to make sure I understand all the current headlight wiring before I start cutting and splicing to make R6 controls work. The problem I have is that the only wire that is getting any voltage at the six prong harness at the left control is the brown/white wire which is flashing...obviously for the turn signals. I traced wiring diagrams and it looks like power should be coming from Blue/yellow and Blue/green for the headlight...which are wired into the Reserve lighting module. However, as I trace these wires upstream to the Reserve lighting module, I notice that NONE of the wires at the module are getting power (with the ignition on)...which means I am not sure how the headlight would ever get power from the Reserve lighting module, if it doesn't have any power. Tracking down all the wires for the Reserve lighting on the diagram, I have no idea where the power comes from...it looks like there is only one incoming wire that is yellow...that is supposed to inform the module when brights are on...right?
I am sure I am missing something really dumb here...but thought I would lean on the expertise of the community for some advice.
Thank you so much in advance.
