I have a 75 with bs38's pods and a 2 into one exhaust open, with a washer welded on to baffle/add back pressure. I've done quite a bit of searching and I think I might have read too many at once.
I'm not sure if the PO re-jetted but the needle does have the clip on the needle one lower than the stock setting (raising the needle). I have them fairly well synced I believe. When I rap the throttle the rpms drop right back down with no hover. My mix screw is at about 1 1/4 turns out. I am still trying to get the mix right.
My problem is One: is seems to run really hot. Like REAL hot. The plugs don't show that I'm either too rich or too lean but I am in the grey color on my left plug and a tan on my right. Two: (and my real problem) When I'm on the highway at about 4500 rpm (65-70mph) it won't go any higher. Giving it more gas doesn't rise it and there is no pull. It is driving me crazy. When I'm on the side roads it seems to pull fine through the gears and pull hard at the power band (3000rpm- 4000) I don't have any popping and there aren't any leaks around my intake that I've found. My valves are set to spec. .002 intake .oo4 exhaust and my cam tension is good.
I've had the carbs off more times than I can remember and are very clean. I did find that on my left carb the thin plastic washer that sits under the clip (it does go under right) of the needle in the slide was missing so I made one out of a plastic the same thickness.
I did find that my clutch was a hard pull and when I adjusted it the PO had turned the screw till it just bottomed (where you would then back off 1/4 turn) and then turned it in about 5 turns So I am working on finding the sweet spot. Like I said it will start to run REAL hot and not want to go into neutral, although it isn't super difficult to find and real easy when cold.
Speaking of cold, when I go to work in the mornings and it's cooler out it runs great (I'm not on the highway though) and then runs rougher when it's hot out on my way home.
Anyways any help would be appreciated.
