Docwits
Well, finally had some time to start working on the build today, thought I would start with a little smoothing/polishing and some maintenance.
I knew the bike had taken a few "falls" but the damage is becoming more and more clear.
First I have attached a pick of the right side cover, not sure if I want to spend hours sanding and polishing to fix the deep scratches or look for a new one on Ebay.
But that is not the "emergency"
I went to drain the fork oil so that I could change it and put new progressive springs in, and found that one of them is stripped beyond repair and the other one is snapped clean off.
Is there another way to drain the oil? If I remove the top caps and turn the forks upside down will that work? I though of drilling out the drain screws, retapping and putting in new bolts but I'm worried about leaving burs in there (I really don't want to rebuild them right now, eventually I am going to shorten them but I wanted to ride with them up in the trees for awhile to determine how much to shorten them.)
Please, I hope someone who is on this site right now can help me so I can get on with the progress, I don't get a lot of time to work on it.
Thanks in advance for your help!
