Hey everyone
First post so here we go
Got a 79 xs650 last night
By jumping the bike (currently missing battery) I was able to get her to start
Sounds great
The clutch lever was very stiff so i figured it needed some adjusting
Goes through all the gears fine
Got it home and tore it apart, did a lot of research and reading trying to figure it out myself but I'm stumped
Took off the left side engine cover, removed the cable from the worm gear and it moves freely (the worm gear)
lubed up the cable and checked for frays, nothin
Pulled out the push rod and cleaned it, looks good
slapped it all back together and tensioned the cable via worm gear
Fully tensioned the cable still had slack so i tightened it up top on the perch a little more
Pulling on the clutch its still pretty stiff, I took off the right side engine cover after draining the oil and i can see the clutch moving as if the push rods are functioning but it's still pretty tight to me but it seems rideable at least compared to what it was, seems like adjusting the worm gear helped a bit but it was fully tightened, i assume the cable is just stretched and should be replaced but if anyone has any insight that would be great
Second problem
Kick start
When I got the bike the kick start seemed kinda messed up
While kicking it there is a bit of resistance but not much just seems kinda mushy
Springs back up so I assume the spring was installed/preloaded correctly
Of course by now its in my hands being examined
before taking the right side cover off I put it in first and attempted to kick it a bit
The bike rolled forward as anticipated
This is where im getting puzzled
with the side cover off I am holding the mechanism in place(kick clip is in the recess) and manually turning the kick start pedal with my hand
I can see the gear on the shaft rotate and slide back on the splines engaging the gearbox
As i turn the kickstart pedal I can see the pressure plate spinning but the pedal is still pretty limp
Pardon my ignorance, I've been messing with it/ researching all day and can't seem to figure it out
Sounds great
Second problem
Kick start
