High ratio primary gears
A higher primary drive ratio (lower numerical, i.e 2.0 instead of, say 2.50) makes the clutch and gearbox spin faster for any given crankshaft RPM. This will give two advantages:
1. Reduce the torque (load) on clutch and gearbox, reduce clutch slippage and increasing reliability, especially in tuned engines with more power and torque.
2.Makes it possible to use a larger rear sprocket, or lower cruising RPM with stock sprocket sizes. The stock sprocket is quite small already. Most all alternative rear hubs require bigger sprockets, if you should want a disc brake spoked wheel, for example.
