High speed wobble??
I think i am on the rite track now,I guess the new tapered steering head bearings have taken a set after 1000 miles and ther was to much slop up front,i adjusted the fall away tighter definately noticed a difference,was able to get up to 160 kilometers (100mph) for first time but ran out off road.There still is a very slight wobble at approx 75/80 mph but way better.I actually over tightened them first and that made it just as bad if now worse,then took the time to try and get 1 inch and thats when i noticed an improvement.Hard to get a good read with all the cables hooked up,the steering will still bounce once when let go.not sure if thats good bad or not revelent.My wheel bearings front and rear r new,did check them anyway,thx There is definately a sweetspot for fallaway to make things work rite,between setting the head bearing and tweekin carbs,its been a full day in the garage,fun work!!
