Just a follow up on my previous post about using Ducati muffler hanger rubber bushings when building your own rearset peg plates.
Here is a short rundown of what I am working on, for one side. So you need twice this amount.
10 mm aluminum plate, 6082T6, I believe
2 pcs aluminum spacers, 30 mm od, 12.5 mm id, 8 mm thick.
4 pcs Ducati "Silentblock", part.no. 76410011A
2 pcs aluminum washers, 25 mm od, 12 mm id, 3 mm thick
I also used M10x1.25, 12 point Ti nuts. Just because.
Early XS650 footpeg rubbers. 20 and 25 mm SS square tubing for the pegs.
SS hinge bracket for pegs, from 4 mm flat bar, TIG welded.
