I think you are asking how its hooked up?
OK here is what is done in my video.
First I always have spare harness that I cut up with just the plugs for ALT/TCI/COIL/REG-REC. This setup was with a 1981 TCI and if you don't have a harness you can buy one from TC Brothers and that's all you need to fire up bike. When I build motors for sale I bench test them and put hours on them before they leave so I have a setup I keep on the side (alt/tci/coil)
You really don't even need the reg/rec hooked up but I did it to test ALT for sale so it does more than one thing.
If you have a spare harness for a TCI setup just cut it up but first plug in the ALT/TCI/reg-rec/Coil plugs and after you are done you will end up with a BLACK (ground)RED (12 volts) BLUE (neutral light) BROWN (12 volts to key on) NOW you have a stand alone wire harness for CHARGING and IGNITION
Now you need a battery and a toggle switch for OFF/ON so you can kill it. If you want to test starter just tap the heavy black wire onto the positive side of battery and starter will spin . If you are making it with a switch for starter just use a starter relay in between and that will work but really not needed for testing.
If you just follow the diagram for TCI that's all you need to fire up. If it was a PAMCO or POINTS motor all you need is 12 volts to unit and it will fire. I have a spare BOYER and I use that also but TCI setup is faster and the easy way to go for testing.
If you need personal help you can contact me at
DADDYGCYCLES@YAHOO.COM
I had bought a simple rolling cart and put a TC Brothers motor stand on it and mounted the TCI/COIL/REG-REC/COIL and gas bottle and just use that also as a test cart. This way I just roll it out of garage and let motor run . If you are going to run more that 5 mins its good to have fan running on motor to keep cool.
Hope this helped a little.
Rich
