okay so i was looking in the left hand control I still do not see how it grounds. None of the wires in the control are a ground.
I hooked everything back up today and the horn/turn signals still dont work. Also my rear break light and dash brake light are not working (using the rear brake), my new M/C still isnt hooked up.
im getting to the point of kicking the bike over im so frustrated.....any help is appreciated.
on top of that I hooked my tank back up and I can not kick it over..... yesterday I did the same thing and it kicked over but one of the throttle cables was tensioned so it was ideling at like 4k so I had to quickly cut it off... Not sure what changed between yesterday and today concerning kicking it started. Its one of those days.
You need to use a VOM on the X1 ohms scale to test for ground on the handle bars. Connect one probe to the battery negative cable, where it connects to the frame. Now touch the other probe to the handle bars. If the bars are grounded, you should see a very low reading in ohms,such as 0 or 1 ohms.
Thanks I will try this. here is my multimeter (i have never really used it before) which setting should I put it on?
So looks like what I need to do to troubleshoot is the following
1) Test if there is a break in my Horn/Turn signal wires running from control into the bucket
-how do I test to see if there is a break in that wire?
2) Is there a fuse that all of those controls go to that may have broke?
Is there something else that I need to look into? Im fumbling here now. Tempted to just buy a new left hand control at this point. (feels like quiting though)
Good and bad news. Good news finally got the bike to kick start again, bad news is I did the volt test VOM from the negative terminal on my battery to the brown wire with the spade? connector on the horn. I tried two ways touching the red probe to the spade while hooked up and pulled the brown wire off and touched it (all with ignition on)....Nothing I didnt get it to move. I did notice the batter in my VOM was dead so I replaced it but I think the battery only comes into play when measuring Ohms and not volts? Could be wrong there. Anyways stuck again, not sure my next move as I didnt touch anything but the handlebar area, not sure why I wouldnt be getting power from the brown wire? (I have some pics I will upload when I am at work)
Side note - Finally got the bike to start I pulled one of the spark plugs to make sure I was still getting a spark, I had it connected but unscrewed laying on the side of the engine case, on a fin, to ground. Kick afew times and no spark. I wire brushed my spark plugs off tried again and boom pretty clean spark. Hooked everything back up and then it kicked over..... Must have fouled them good when I had the idele messed up. Still need to adjust the idle screws but down to a much more reasonable 1.2-1.4 rpm range not 5k.
RESOLVED!
Okay so I had one ground wire that wasn't connected to anything in the headlight bucket which I thought was abandon the whole time I looked at my notes I had indicated that one of the junctions only have three brown wires one from the handlebars to two in the bucket so I didn't question it. I had a friend come over and he said why was that brown not connected we connected the brown and Viola everything started working horn turn signals brake light was just one brown wire in the bucket.
To sum up my issues
1 black ground wire broke in bucket to headlight
2 bad ground connection under gauge/triple tree point had to sand clean
3 brown hot wire not connected in bucket which controlled horn turn signal and brake light
Thanks everybody couldn't of done it without you.
Once we figured out the horn didn't have power I've been tested the wire that went from the flasher relay to the battery it had continuity so I knew there wasn't a break pass my handlebars then finally after looking at the wiring diagram realized that you probably needed to be another brown connection point that wasn't been made to complete the circuit and the rest is history
