tons
I just started changing the oil in a bike I just bought...I took out the oil filter and it was covered in metal shavings!! How bad is this?? What could it be?? Was I had by the PO??
The sump filter had no aluminum compared to the oil filter does this mean anything??Did you remove the sump filter, or just the one on the side? The sump filter will probably be have a lot of aluminum and plastic. Its less a matter of miles, than age. If you're going to screw with old bikes, this is what you get. Buy a manual and ask for help here-it's not that hard.
John
No I havent removed the sump filter yet ...Some other xs websites suggested not tearing into it right away?? m
I think that's because some problems may resolve themselves and others may show up, if you wait awhile to start fixing things. But the sump filter - it's either broken or not right now. Would be best to check it out right away. Many ways to fix it if it's broken. My po used a fiberglass car body repair kit on it. Tighten the bolts back in a cris-cross pattern, and while you're at it, don't break them off
The sump filter has a pencil eraser sized hole in it, and and only a couple metal shavings but the oil filter had alot of shavings on it.
