Punkskalar
Hugh's HandBuilt
HandBuilt from DOM Tubing and Laser Cut Steel
Stainless Hardware Provided
Comfort and Killer looks
Excellent Alternative to Clip-Ons or Drag Bars
Fully TIG Welded
Bolt Pattern is 3.93″ Center to Center, may fit other models
May Require Gauge Relocation / Removal
Inspired by Hugh's very first build, these bars are the perfect fit for your XS650 or SR500 (and others, check bolt pattern on upper triple tree). The XS650 and other bikes suffer from a short top tube, and when combined with drag bars or clip-ons, can become rather cramped.
We built the Hugh's HandBuilt Speedster bars as a solution for a less cramped cockpit than your standard drag bars or clip-ons. With just the right angle built into the pullback of these bars, they are both comfortable and look killer.
At 31″ wide, we ship these out a tad longer than needed, so you can custom fit them to your bike and trim the width as desired.
These are HandBuilt in house, TIG Welded using DOM 7/8″ OD Tubing and Laser Cut Mount. Stainless hardware is provided.
The mounting holes are tapped for M12 x 1.75 Hardware, and are 3.93″ center to center (if you find these will fit other models, please let us know and we will update as needed. Thanks folks!)
*These will mount to the OEM rubber mounts in your triple tree, however we recommend our Hugh's HandBuilt Solid Riser Bushings to really clean up your front end and get rid of the "squirm"in the bars.
These are in stock, and available at www.hughshandbuilt.com
Hugh
Fully TIG Welded
Hugh
