kvanderploeg
The Dutch Terror
Pay the man! Thank you!
Kent
Kent
the kit looks great! any chance this would work with a different lever/MC setup? this one looks good with the stock XS stuff blend so well with my setup.
Mine arrived today....holy crap is the reserviorhttp://www.google.com/url?sa=t&rct=...-CKMvz2VU8gpU5q5g&sig2=cvoGlhv96YYJPf7sFEZifg small. I've never seen one this small. can't wait to get this baby on.
Hugh...
I can't see the pics at work, sadly, but I have read through the instructions, and this looks fantastic! Early on, when you first started this, I had expressed interest, and since I'm retiring soon, I may just have the time to undertake this. As luck would have it, in the interim I recently replaced my lever and perch and got my bike shifting quite well, but neutral's still a little shy, and first can be a bit ethereal , so there is still the incentive to go the "Hugh Route".
Do you think these kits will be reasonably accessible in the near term? I'm excited about a kit that apparently does not require me to do a lot of machining on my side cover.
Thanks very much for this. Can't wait to get home and see the pics!
Edit: One other quick question, Hugh...
In order to maximize the adjustability of my clutch, I had added a Mike's cable adjuster (stock type, as at the lever perch) to the side cover-end of the cable. I had to tap threads in the existing side cover hole (referenced in your instructions) so that the adjuster could thread in. Would you happen to know whether your slave cylinder threads are perchance the same as those on a stock cable adjuster barrel, or would I have to find another way to secure the slave cylinder?
Thank you!
TC
