FLEA
XS650 Guru
was only 1/2 joking but when it arrives will definitly do a visual before fitting to the 650.from the photos a bit of adaption doesnt look to hard to do.trouble is iv got another xs which might have to come first
why pull the rod out??
Who else out there has the totally awesome man-skills to fuck up this install twice? Me, that's who!!
I got the kit installed and running great. I didn't want to cut or file anything down without a test, so I did a 15 mile round trip test drive. I came back and adjusted the lever a bit, which meant that I was pulling the lever in a bunch as I tried to get the feel perfect. After I got the feel right, the shit hit the fan. The bike began to lurch forward and stall when I disengaged the clutch. I assumed that I had air in the line, so I tried to bleed it.
Bleeding it did not work out very well for me. I let the piston pop out too far. I continued bleeding it, until the piston popped out again. After this time, I couldn't get it to respond at all. I though that maybe I had let too much fluid escape, so I popped the master cylinder open and topped it off.
Still nothing. No pressure, and almost no movement in the piston.
I never knew that I was so special.
This is random but instead of filing the head of the lever bolt I just reversed it. That and aftermarket controls gave me the best clearance.
Anyone using a different lever?
Posted via Mobile
