If you have the head off, I would change out the front cam chain guide, age as much as wear requires that. The tensioner guide seldom needs replacing. Spend the money to replace the cam chain.
22,000 miles the chain needs replacing anyway.
Replace the valve seals, lap the valves. A cleanup of the casting marks in the intake and exhaust ports. Don't enlarge or chagne the shape just remove the casting marks.
Replace the stock valve adjusters with the Porsche elephant foot adjusters. Needs mods to the rocker arm but well worth the effort. Makes easier adjustment and valves run quieter.
Personally I would do Mike's 750 kit as well. Runs stronger with much less vibes above 4000 rpms.
One more thing, the Harley Muffler clamps are the best on the market. To bad they only make them in 1 3/4 inch size. The only ones I found that work. Especially when useing a 1 3/4 inch muff on a 1.5 inch pipe. The adapter shims just don't seal with any other clamp.
