THEbananaDZL
100% First Timer
So this is what I have, the bike will run and idle perfect, but when trying to rev up it seems the ignition wont advance timing and the bike with sputter, pop, and never really rev up.
Bike is a 1981, mods are PMA from Hughs , PAMCO kit from Mikes, XS pod filters, carbs cleaned and rejetted +2 mains +1 pilot, headers only until I finish my exhaust, kick only....
Now I don't believe this to be a fuel problem as I have had no chance from stock jets to the larger ones, even with a shot of ether there is no change. These are the things I have tried.
-Timed TDC mark at idle- runs great
-While under 50% throttle adjusted PAMCO plate to which there was no change in poor running
-Rubber banded advance weights down, no change
-Removed weight springs, no change
-Reread Petes install and all looks to be good (solid instructions pete)
-Did the snap back test.... Would work fine when bolts on advance rod were back off slightly, when tightened they would stick. (I dont have a Tq wrench to goes down to 90 in lbs)
-With all the above things I had about 75% throttle input and moved the timing plate with NO CHANGE.
Now I installed this a little over a year ago then left for basic military training, now that I have the time to get back to working on it I would like to get her on the road. What should be my next step? Where did I go wrong? Or what else should I search? The reason I believe it to be in the advance is cause it idles like a champ when set at the correct timing.... just starts to shudder, pop, and not rev up much at all under throttle.
Any and all help would be great... I spent my 23rd birthday yesterday staring at it lost, confused, and lonely...
Great site, tons of info, I troll around here often.... hoping someone much wiser than I can give me a quick hand. Thanks!
-Alec
-Alec
