Ignition coils off other bikes
I and several others have been using a Honda "MP08" stamped coil with a 3 ohm primary for a long time with no issues. It is plentiful and inexpensive and does not make anybody any money.
There are no precision resistors in the TCI, which says the 1/2 ohm difference completely insignificant. Not only are there no precision resistors, but all the components on the board have 30 years of aging and drift. But I defy anybody to be able to tell that from the operation of a TCI. ;)
With the Honda coil, what type of wires and plugs and caps are you using? Resistor or non?
Non-resistor wires, aka metallic core wires. Non-resistor plugs. NGK resistor caps.
Edit, just to add here, those are 7mm wires that fit the best in the Honda coils. I can only recommend the MP08 type Honda coil, the two generations before that (much larger coils) have a worse than "BAD" reputation.
Rodger that! Thank you. Any idea if this coil would work with a GN250 box? I'm not too confident in my TCI box as I've never seen my motor run as of yet.
The MP08 "Honda" style coil will work with OEM TCI or the GN250 "Gonzo" igniter.
There is a troubleshooting method for XS TCI ignition systems that basically involves checking and eliminating everything else except the TCI Igniter Unit - attached.
  • TCI Trouble Chart.pdf
Thank you again! I'm basically trying to hear this motor run for as cheap as possible right now, and go from there. I found many good threads on testing and I did all the ones I could find. Coils has good primary and secondary resistance. Pick up with both around 750 ohms each. Got power to the coil all day long.
There are a couple "semi-off-the-wall" checks before replacing parts:
Verify good, solid continuity of engine cases to battery (-);
Test resistance of pick-up wires at the disconnected TCI Igniter connector (they can break) W/R to Bk/W, W/G to Bk/W
I have a dumbass question! So I'm looking for 12v consistently throughout the cases and frame?
No volts, just really, really good continuity to ground (battery -) - as in 0.000 Ohms:)
And should I test both sides of the connector or test resistance on the TCI unit itself? Is the a number I should be looking for?
Yes on the ohmmeter, battery negative to cases.
Unplug the TCI and test the pick-up wires back through the harness - should read the same resistance as pick-up specs (or very close to 750 Ohms).
There are no specs - that I'm aware - for the TCI unit itself
