I would suspect any wiring change from the original harness.
Undo any fixes and leave those wires hanging until you can get a volt/ohm meter and a manual.
Put a fuse back in and turn the ignition on. If the fuse hold then you're on the right track.
Probe each wire checking for voltage and ohm each black ground wire to the frame to test for continuity.
Refer to the manual to find out what and where each hot wire goes.
