Rlauchard
Hi,
Me again...the newb that doesn't work on motors or cars, but is trying to learn...now I'm in it (I think). 1981 XS650SH.
So, I'm leaking oil...not a lot, but obviously as I ride longer the more oil that leaks. Oil is dripping from the bottom frame and the bolts under the engine. I took the left crankcase off and the stator wires have oil on them as though it is dripping from the seal.
Here is a link to a video showing my push rod seal and the play with the outer push rod. I believe that this is the culprit as I'm not seeing leaks from my gasket areas.
Responses needed:
1. Do you agree that this is too much play and will cause oil leaking?
2. I would like to convert to a single pushrod. I can't find a good post on how...I think it would go like this...can you confirm?
3. I would need a new clutch pushrod bushing (http://www.mikesxs.net/product/01-2020.html) and a new clutch pushrod oil seal (http://www.mikesxs.net/product/01-9019.html) and should follow the directions on mikesxs (http://www.mikesxs.net/faq.html) in the clutch section.
As always, I'm scared, but eager...thanks for the assistance. You guys are great!
Responses needed:
- remove the outer pushrod (20 in image below)
- remove the middle ball bearing (18 in image below)
- remove the inner pushrod (19 in image below)
- replace with http://www.mikesxs.net/product/39-6511.html
- make sure that the 'smaller' end is in the worm gear
