Progress report on my antique lathe:
The compound lock problem was a case of a broken off set screw jamming up the threads. The location was where logic dictated it would be, but I'd tried putting a bolt in there. Ran it down snug and it had exactly zero effect on locking the compound. Chased it with a bottoming tap to get the broken bits out of the threads and all is well.
The lead screw nut for the compound I had to fabricate, but it also went right where I thought it must. Conveniently enough, the lead screw is a common 7/16-14 thread so I was able to TIG a post to an ordinary hex nut and fix that issue as well.
Now all I have to do is see about truing up the chuck a little better and learn to grind HSS lathe tools and I should be able to make chips.
