74 75 didn't have those partz, use two throttle cables.I’m looking for the x bracket that goes on the caps and the angle piece that connects the bottom of a pair of 74-75 bs 38s. Also lookin for jets in good shape if anyone has stuff for sale
Shoot my bad I’ll try to get it the right place
Oh boy than I’m really shootin in the dark. These only have one throttle cable and one choke lever. I’ll post a pick of them tomorrow74 75 didn't have those partz, use two throttle cables.
I’m sorry I’ve got them swapped right for left in that pic see the choke lever? So that brass post that sticks dow into the bowl supplies the choke? Cus these carbs have a crossover pipe supplying the right side choke from the left one. Should I post a pic with All the hoses on?That's part of the mystery, 74-75 carbs don't have that choke feed pipe on the RH carb, they get the choke mixture through a crossover tube from the LH carb.
I’m sorry I’ve got them swapped right for left in that pic see the choke lever? Cus these carbs have a crossover pipe supplying the right side choke from the left one. Should I post a pic with All the hoses on?
Got ya, makes sense. The singe throttle is what’s throwing it off. Because the carbs have to be synced together and that’s dang near impossible without them being mounted solid to each other.No problem, I saw they were crossed.
So that brass post that sticks down into the bowl supplies the choke?
Yes that's' why it's only on the LH carb.
Have these carbs ever run?
So what I really need is to get throttle on the right carb set back up for a cable somehow and switch to 1 into 2 cable?Yes, the right carb has no choke feed tube because it has no choke. They left it out because there was no need for it.
