I'm sorry its in the 200's for the main fuse
I don't remember off hand whether the circuits were live or not when I took the readings but I do know when I had the key in the on position there was no current passing through the main fuse. The fuse is good, but there is no continuity between the blades holding the fuse even when the fuse is in place.
Any suggestions on inline fuses? Tube style or blade fuses? Looking on ebay they are about 2 or $3 a pop. Not bad at all if it solves the problem. And if it doesn't, it still isn't bad.
It's not the resistance that matters. What matters is that the voltage is the same on both sides, and past the clips. If it is, changing the fuse box won't fix your problem.
Yes, it is the resistance that matters.
I could get 12V through at 1 amp and it wouldn't do me much good.
You only need to be concerned with the voltage. If something tried to draw 2 amps from a 12 volt source that could only provide 1 amp, the voltage would drop to 6.
People will spend lots of money and waste lots of time shooting in the dark with new parts. You may need a new fuse box before your bike will start. I'm trying to tell you how to see if you need a new fuse box.
Another way to do it is to temporarily fix whatever fusebox you have and see if it helps. Then buy a new fuse box if you need one.
If you understand Ohm's Law in DC circuirts, then high resistance means there will be a high voltage drop across the fuse holders,
Doing a "temporary fix " to an old worn out component, has no benefit when a proper repair costs about $10.00 to $12.00.
