cooltouch,
The PAMCO itself uses .010 Amp of power. That's 10 milliamperes. A 2.5 Ohms coil will use 14.5/2.5 = 5.8 Amps when it is on. The 60 degree dwell angle rotor means that the coil is on for 2 X 60 = 120 degrees or 120/360 = .33 or 33% of the time, so the average current for the coil is .33 X 5.8 = 1.9 Amps + the .010 PAMCO current for a total of 1.91 Amps.
If you use Mikes 17-6922 coil that produces 37,000 volts, its primary resistance is 4.5 Ohms so it will draw only 3.2 Amps when it is on, or an average of .33 X 3.2 = 1.06 Amps. As the coil heats up, its resistance increases, so for all practical purposes, you are talking 1 Amp.
The PAMCO itself will also work all the way down to 3 volts. It's the coil that needs the voltage, but PAMCO's have been tested down to 5 volts and they will still produce a spark that's good enough to fire the engine.
I also think that some other systems require a minimum engine speed to work, like 200 RPM. The PAMCO will work with any speed. Like, 1/2 of an RPM, so it is excellent for starting if the engine will not turn over very fast.
So, here's the spec:
Power required: 5 to 15 Volts DC @ 1 Amp (with the 17-6822 coil)
Minimum Rotation speed: No minimum
Output Voltage with the 17-6822 coil: 37,000 V @ 14.5 input. 15,000v @ 6 Volts.
Amount of backward rotation of the crank to produce "kickback" during a kick start: 240 degrees. This spec is important for kick start bikes. The points system can produce a dangerous kickback with as little as 1 degree of backwards rotation of the crankshaft.
