Would it be possible to lift up the engine still in the frame and with carbs, electrics etc. still in place? Just by loosen the engine/frame bolts and maybe only remove the upper mounting brackets? or what would one have to remove to be able to lift the engine still in place?
I need to lift the middle/rear part of the engine up at least 2-3 cm. And I prefer not to unmount anything or remove the engine from the frame.
I need to do this to have complete clear space in front of the lower gear train bolt hole (90 degrees). No part of the frame in front of it like it is now.
Martin
Martin
