thanks for that skull...the bike's electrics certainly need a thorough going over as its not been used for 6 years at least!
I now suspect the ignition switch.
Yesterday I checked the flasher wiring and switch . I removed the cancelling unit and cleaned all contacts and connectors and replaced the relay. Eventually I got the flashers working .There was definitely bad connections in both the switch and headlamp bowl.
I have noticed that the red warning light occasionaly comes on immediately but mostly some seconds later and wiggling the key sometimes turns it off or on,... so I reckon water has got into the ignition switch.
Still haven't found the neutral indicator .?
