losing spark
zookage
Hudson Valley NY
hey guys finally got the carbs done and installed. now I'm losing spark! it's there at first then I lose it. I'm lost! coil? ground? any clues or hints would be greatly appreciated
welcome zookage .
You need to tell us more about your bike in order for us to help you.
What year ..... is it points and advance or electronic ignition....... is the bike stock
If you've gone over the wiring and checked the fuse box and it looks good, then I'd suspect coil then TCI box
The guys here have cooked up a simple test for weak TCI trigger magnets.
Simply unplug the regulator, start the bike, see if it runs any better (or different)...
The TCI is very voltage sensitive. On my 81 if the voltage drops below 12.5 to 13 volts it don't like it. starts to lose power, then as voltage drops further it idles ok but won't take throttle.
I might suggest you read the charging system guide.
