TIMING CHAIN GUIDE p/n 256-12231-01-00 - Chapter 3: The Analysis
I have read all the stuff about these danged guides and the difficulties with the MikesXS aftermarket parts. I have searched high and low for an NOS example of my own and I’ve come up empty. Judging by the rapidity of the disappearance of these things from all of the usual parts suppliers, I’d say that
SOMEbody,
SOMEwhere has got a sh!tload of these frickin’ things and they're holding onto them.
Well, f@ck ‘em.
I wanna ride my bike and so, I need a guide and it has to fit and work properly. For that reason, I spent this morning doing a reasonably thorough and objective analysis of my (rapidly growing) collection of timing chain guides. So far, I have four of them and I’ve got two more used OEM guides arriving shortly so I’ll have an even half dozen at my disposal (one of which is a loaner from Lakeview - but it is an actual OEM guide in decent condition).
For the purpose of this analysis, my collection includes:
- AGS - this is the loaner from Lakeview. I will use this one as the benchmark against which I will compare the others. It is out of a (I think) mid-70s XS650B-D and so it has some miles on it, but the plastic surface looks good and has only very light scuffing;
- P1 - this is my failed guide from Lucille. It has NO plastic at all and so it consists solely of the metal “shoe“;
- M1 - this is an aftermarket XS650 Direct / MikesXS part as described earlier. It has the slightly misaligned mounting holes and softer rubbery surface versus the very hard plastic surface found on the OEM parts;
- M2 - another MikesXS part similar to M1.
I had a good hard stare at the timing chain guide and thought about the function of the part and how it works with the other parts in the timing drive system and then I thought about what I can measure accurately with my available metrology equipment (some micrometers and a digital vernier caliper). I determined that there are really only two dimensions that I can easily measure
and that really count.
The key dimension is the distance from the centreline of the timing chain run (
as defined by an imaginary line between the centres of the crankshaft and the camshaft) to the surface of the timing chain guide. That timing chain guide surface is where the chain contacts the guide - and
not the other parts of the guide body (specifically, not the metal parts of the guide).
The other key point is that the measurements would best be made from a machined surface and
not the rough cast surface of the cylinder barrel body exterior. Every cylinder casting is going to be different but Yamaha actually controlled the position of the guide in a clever way by using those hollow threaded collars
AND the shoulder bolts to secure the guide to the inside surface of the timing chain cavity. Thus, the position of the ends of those little threaded collars
control the position of the metallic component of the guide (
see the photo below and note the little silver cylinders down in the timing chain cavity).
Unfortunately, I cannot measure the actual distance from the line defined by the centrelines of the cam and crank shafts to the guide surface - so I’ll have to use a surrogate measurement from a fixed machined datum on the cylinder barrel body to the guide surface at two points. It’s not ideal, but it’s the best I can do.
To make the measurements, I installed each of the four guides in a cylinder barrel (
another loaner from Lakeview) using the stock OEM fasteners, and then I measured from a fixed datum on the mounting surface of the cam chain adjuster mounting pad to the bottom of the U-shaped channel in each guide (
see the photo below for an example of how the measurements were made).
I did this measurement at the
TOP of the cylinder barrel (
the head gasket surface) and at the
BOTTOM of the barrel (
the base gasket surface).
The first measurement is designated
Dimension A and the second is
Dimension B in the charts below. The absolute value of each dimension is of interest as is the
difference between them because that difference number shows the “tilt” of the guide in the cylinder head assembly.
Again, I fully recognize that this analysis is not ideal, but it is the best I can do with what I have. So, here is a sketch of the measurement scheme and a close-up of the data chart.
In the above chart,
Dimensions C and
D are estimates of the depth of the channel in each timing chain guide. While not particularly important for the function of the part, this data shows something about the consistency of the manufacturing processes of the OEM and the aftermarket suppliers. Actually, MikesXS doesn’t do too badly on this score, IMO.
ANALYSIS:
The data shows that the MikesXS guides protrude about 0.81 mm (about 0.032”) less into the timing chain cavity at the head gasket level (the average of the values of
Dimension A) and around 0.13 mm (about 0.005”) at the base gasket level (
Dimension B). What happens between those two datums is likely a reasonably linear variation - but I simply don’t know and so your guess is as good as mine. In the chart, the data for the P1 guide (the nude failed guide from Lucille) is estimated from measurements of the metal shoe.
This means that the MikesXS guide will allow the timing chain driven run to be a tiny bit longer than the OEM guide - thus, the cam timing will be slightly retarded from the OEM specs. How this will affect the timing of the camshaft in a quantitative way, I don’t know exactly, but I’d guess that the difference will be small.
In terms of
Dimensions C and
D - the depth of the “groove” in the guide plastic component:
- the MikeXS guides average 0.28 mm (about 0.007”) deeper than those of the OEM guide.
- I could “estimate” the depth of the groove in the P1 guide, but that would be torturing the data pretty harshly because that guide doesn’t actually have ANY plastic left on it at all.
The other key dimension is the
difference between
Dimension A and
Dimension B - which is the “tilt” of the guide in the timing chain cavity of the cylinder barrel. Again, this affects the path over which the timing chain runs and thus it affects the timing of the camshaft relative to the crankshaft.
In the chart this quantity is designated
DELTA (the little triangle symbol). The data shows that the MikesXS guides tilt a bit more than the OEM guides - perhaps by around 0.9 mm or about 0.36”. What this means in terms of cam timing....is a matter for conjecture.
DISCUSSION:
While there appear to be trends in the data, the small sample size of OEM and MikesXS parts makes it difficult to give a conclusive answer as to whether the MikesXS parts differ
significantly from the OEM parts in ways that would affect how they
actually work in an engine.
For this analysis, I only had
one intact OEM part (
AGS) and
two MikesXS parts (the
P1 part has no plastic guide surface at all). Also, the
AGS part has been in service, while both of the
MikesXS parts (
M1 and
M2) are brand new and also, they are made of a different material, which will have entirely different shrinkage characteristics coming out of the mold.
That raises the issue of production tolerances. Molding plastic and rubber parts is something with which I do have some experience and I can tell you that getting a few thousandths of an inch variation in molded parts is common and nobody can do much about it.
Thus, the variation between the two MikesXS parts and between the two OEM parts seems to be comparable - showing that the production variation between the two manufacturers is not too different.
CONCLUSION:
Well, hmmm.....my gut reaction is that the major differences between the OEM and MikesXS parts can be summarized as follows:
- The dimensional differences are detectable - but likely not sufficient to impair the functionality of the MikesXS parts.
- The hole alignment differences are also detectable, but can be mitigated by applying a dab of sealant under the crush washers - and the mounting of the MikesXS guides in the cylinder barrel is not affected in a material way;
- The one major difference is the softness of the plastic / rubber moulded component and in my view, it cannot be concluded that this is a disadvantage of the MikesXS guide.
The OEM guide has a history of being fragile and when it does wear out, large pieces of the hard plastic component flake off and land in the engine sump. Will the MikesXS guide do that....I don’t know. It really remains the be seen if the MikesXS part will suffer from durability problems - so all one can do is watch the oil for bits of rubbery stuff.
Soooo, I am going to install MikesXS part
M2 in Lucille’s engine and I’ll be watching the oil carefully for bits of rubber.
All of this experience with my dear old Lucille has shown that even if the entire plastic component falls off the danged timing chain guide, the tough old XS650 engine will keep going and it will get you there (albeit with a bit of extra noise).
Comments welcome.
Pete
