Very nice! I also have a pair of those early petcocks on my to-do list. What liquid/solvent did you use in your ultrasonic?
Thanks! 50 / 50 ratio of simple green and water.
@Mailman did you happen to get the True Value part number or the dimensions of the grommet? I have a True Value a few blocks from me. I could use a couple of those. Nice work.So I ran to True Value Hardware store to rummage through their cabinets , looking for a suitable grommet I could use. I found one that was just about perfect. Heavier than most with thick squared edges.
View attachment 185183 View attachment 185184
The original part had one flat side, where it presses into the side cover, so I trimmed off one side, the fit was perfect.
View attachment 185185 View attachment 185186
I didn’t want to cut through it to slip over the wiring harness, so I removed the wires from the multi plug and ran the wiring harness through the grommet, the end result was just perfect! And it only cost $1.20
View attachment 185187 View attachment 185188
I agree Pete. Even the motorcycle market magazines like "Just Bikes" can come up with some treasures like these two.
$7900 & $8995 (AUD) respectively and something to give inspiration to the frustrated retro-mod rebuilder.
Hmmmmmmm...... maybe I spent too much fixing mine up? Oh well.....
Incidentally, I got my old bird fixed up after the fall. That was a hundred dollar lesson. Let's see if I'm a slow learner.
Cheers
One of my favourite magazines is called Motorcycle Classics
Coming along very well, Bob!I haven’t touched my motor in a while, I’ve been busy doing other stuff lately. So today I went out and started re assembling my clutch. I’ve had the friction plates soaking in fresh oil, I removed the clutch basket and filed all the grooves smooth , where the plates had worn notches, put it back on and torqued it down.
It sure is nice and easy to install a clutch up on a bench with the motor laying on its side! Then I dropped the screws and springs and spacers all in.
Torqued em down and the clutch is done!
All that’s left is to replace the right side cover and the motor will be ready to drop back in the frame!
Daniel would be pleased.
Very nice lookin torque wrench there too.
Remember to dial it back to Zero also.
