kazdika
Hey
I recently got my bike running but ended up leaving my switches on and now my 12v minimalist battery that I bought from 650central is almost drained. I'm running a boyer ignition, Hugh's PMA with regulator rectifier and kick start only. I was able to start and run the bike but had to leave my headlight and tail light switch off in order to start. After it was running I can turn my lights on and it still seems to run fine
Can I cause any damage to the ignition or coil or anything runing my battery like this?
Will the system charge the battery while I'm riding or should I charge the battery separately?
And if I need to charge this battery can I use a normal 12v charger?
I searched the forum but couldnt find anythin similar and I'm kinda confused when it comes to this so any help is much appreciated!
Thanks
Thanks
