Well I'll be 70 early next year and I'm having a blast with the 650 I got 3 years ago Seems like we've earned the right to have a toy or two by this point in our lives. Enjoy!
Just finished doing the Minton mod's to my front forks - I had replaced the OEM springs a couple of years ago with Progressives. Per 5twins comments, used a #45 bit for the two holes at the top. Had a new 6mm drill bit that I used on the lower four - it sort of splits the difference in diameter between #1 and 1/4" bits. Polished the metering rods and put in new All Balls elastomeric seals and enough 10w fork oil to come to 6" below the fork tops. Makes a noticeable difference in ride quality - soaks up the bumps much better than before when I was using the "spec" amount of 15w fork oil.
