dr mac
Ok I have a 8/72 ? TX650 with over length tubes and drum brakes. Then one with the standard length forks and front disc brake and W type aluminum wheels.
Can I use the disc brake forks on the TX with the drum brake wheel.
Also since I need to clean the carbs on all . wich carbs to use on the TX . I have the following carbs off a 72 model the TX the 75,76 or what ever it turns out to be .And then two 78 carbs.
Also can I use petcocks off a 78 on the TX tank.
Also plan on lowering the front of the TX and installing rebel shocks on the back .
Guess what I'am saying is I want to lower the TX front and back , remove about 3 inches of seat foam and recover ( already removed the foam as seat was in bad shape ) in brown leather ( well I hope in leather) .
then ride the wheels off it untill next one is done .
So what is the best parts to use.
thanks
Dr mac
thanks
Dr mac
